Rip 3D Blu-ray to 3D AVI
05/27/2020
Do you want to rip 3D Blu-ray to 3D video for backup or for playback on 3D TV solely? Then you have come to the right place. This article tells how to rip 3D Blu-ray to 3D AVI, a 3D video format supported by most 3D TVs and 3D video players, with DVDFab Blu-ray Ripper. DVDFab Blu-ray Ripper is a professional 3D Blu-ray to 3D AVI converter that can rip 3D Blu-ray to 3D AVI at fast speed. It is very easy to use, and you can finish the converting process with only several mouse clicks. Now let me show you how to rip 3D Blu-ray to 3D AVI with DVDFab Blu-ray Ripper.
Step 1: Load the source
Step 2: Choose the 3D AVI profile
Navigate to the profile library on the top left corner of the main interface, choose Format > Video > Filter, check the 3D option and choose the 3D AVI format.
Step 3: Customize your video
After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio track, subtitles, and define the names of the chosen titles. Click the “Advanced Settings” icon, you can set the parameters of video/audio and choose the 3D type. Click the “Editor” icon, you can edit the video with the built-in editor.
Navigate to the bottom of the main interface and click the "folder" icon to select a directory to save the output video.
Click the “Start” button to start the process of ripping Blu-ray 3D to 3D AVI video.
Do you also want to convert videos in other formats to AVI format? Click AVI Video Converter to learn more information.
