"Is it possible to change the color of a video"
"Are there any tips to correct video color?"
"What is the best video color correction software?"
You are not a trained colorist, yet your post-production requires you to play that role. This is especially true on the corporate, indie companies. Do you feel it complicated to conduct video color correction? Well, you don't need to. Because today, we are going to help you out by offering you some tips and tools for color correction.
Section One: What is video color correction?
Video Color Correction
In the color process of your post-production, two parts are involved: video color correction and color grading.
Color correction: Normally speaking, color correction is usually done first. Because raw footage tends to be over-saturated and the colors need to be balanced out. And the color correction process is to fix color issues and make the footage appear as naturalistic as possible, aiming to make video colors look clean and real, as human eyes would see them in the real world.
Color grading: This is the second step. Color grading is also technical, but differently, it more concerns video atmosphere and emotion. For example, darker tones may be used to elevate the storytelling in a horror film. This process is not essential unless you want your film seems to be as realistic as possible.
Section Two: Why do we need to correct video color?
Even if you use the same camera and lights to shot, chances are that you find your hue, saturation, and brightness have changed greatly from one camera to another. When this thing happens, you are required to bring your video color in line with what your eye perceives.
Section Three: Top tips for video color correction
Below are some tips for you when it comes to color correction
  • White balance: set in-camera before shooting, but during the color process, you can adjust anything that might be a little off. During color grading, you can make the white more beige, cooler, or warmer.
  • Scopes: waveform, Histogram, Vectorscope- visually indicates the amount of color in an image.
  • Curves: helps you create points to manipulate the highlights, shadows, whites, blacks, etc.
  • Saturation: the intensity of the colors. When you make it higher it removes greys in the color, lower it adds more grey.
  • Brightness: controls the level of light in the colors. It either adds white into the color or black.
Section Four: Top tools for video color correction
Find the best video color editor isn't easy at all given that numerous tools are designed to do this. But don't worry. Because we have prepared the top video color correction software for you, both AI-powered and none AI-powered.
Part 1: AI-powered video color correction software
Why choose AI video color editor?
Whether we like it or not, Artificial Intelligence (AI) is coming for our jobs for selecting, editing, filming, and sharing video clips online. It can help us create more personalized and customized videos resulting in higher resolution fast and easy.
(1) DVDFab Video Enhancer AI
  • Improve video quality up to 4k automatically
  • One of the few video enhancers supported by Artificial Intelligence
  • Upscale old videos to a better quality
  • Work fast without quality loss
  • The best video upscaler offering a free trial up to 30 days without limitations
  • Easy-to-use and suitable for both beginner and expert
 i  Free Download
AI color correction
How to use DVDFab Video Enhancer AI to improve video quality automatically:
  • Download and install this video enhancer on Windows
  • Launch it and add your videos
  • Select an AI Model like For Movie Video, For Home Video, and For Web Video
  • Set output format, resolution, bitrate
  • Click the button of Start
Color correction video
Then, DVDFab Video Enhancer AI will work fast to upscale your video automatically. There is no need for you to worry about the image contrast, color, brightness, saturation, noise, etc., since this AI video enhancer trained by machine learning models will set all of these parameters based on users’ preference.
(2) DVDFab Enlarger AI
Applied with super-resolution technology - deep learning, DVDFab Enlarger AI can enhance video from 480p to 1080p, or even from 1080p to 4K. Apart from this, it is able to enlarge the video images by 300% without losing any quality.
Features of this video color editor software are:
  • Upscale old videos quality and resolution to make them shine again
  • Analyze the pixels of the images using neural networks
  • Upscale video image by adding great details
  • Set your video clips per your liking
How to use it for video color correction?
The first thing that should be reminded is that this video color correct function is integrated into DVD to Blu-ray Converter, DVD Ripper, Blu-ray Ripper, and Video Converter modules. Let's take the Converter module as an example and then check out the detailed information of this AI video color editor.
Step 1: Get this best video color corrector on your computer
Click the below button to download and install this video color corrector software on your windows-running PC.
 i  Free Download
Step 2: Upload your video clip
After starting it, you can locate the converter module and then select a video format to be converted from the Enlarger AI tab. And then, drag and drop your video to the interface.
Step 3: Customize your video clip following your need
Two buttons: advanced setting and video edit are reachable if you need to customize your video per your liking.
Video color correction
Step 4: Output your color corrected video
Hit the "Start" button to initiate and output your color corrected video with this AI-powered editor.
Note: If you are want to know or curious about how to ai video upscaling with this enlarger AI, here is the link for you.
(3) Hypercube
Hypercube, an AI video maker, offers skilled experts for people who are experienced and understand the knits and grits. Holding an idea that nothing grabs attention better than a well-crafted story, this video makes concerns to build an emotional connection between the companies and their audiences.
Video enhancer
  • Create a strong storyline
  • Low cost and affordable
  • Get visual concepts and style
  • Change per your liking
  • Support video sharing
(4) Rawshorts
Rawshorts is an artificial intelligence video editor and text to video maker that offers the most complex video tools for users to help them in creating marketing, explainer, and demo videos for the web and social media. Besides, it is designed with a drag and drop option so that you can choose from the pre-existing video editing template, upload your video clips, and more.
  • A range of video templates for you to choose from
  • Allow you to upload videos as well as for trim them
  • Add text, media, or other effects to videos without difficulty
Part 2: None AI-powered video color correction software
Since you've already known why most people choose AI-powered video color editor software and what are these best ones, here we also prepared some none AI-powered tools for you to add more chances and make sure you can find the most comfortable one to use.
(1) Wondershare FilmoraPro
Are you looking for a video editing software that can help you create professional-looking videos? If you do, then FilmoraPro is the one for you. With this software in your hand, you are empowered to produce videos with compositing, motion graphics, special effects, etc. Though it is powerful, it is quite easy to be used to achieve video color correction by adjusting color scopes, such as Parade, Vectorscope, Histogram, and Waveform.
Features of this video color editor are:
  • Correct video color as easy as possible
  • Offer various video tones to use
  • Highly customizable
(2) DaVinci Resolve Lite
This one is particularly for people who are trying to find a free program and are beginners for video color correction. DaVinci Resolve includes all of the features provided by the full DaVinci Resolve program. There are a few things to be noticed while you are using it. First, videos with only UHD resolutions or less than that are supported. Second, no stereo 3D support is available. Third, effects like noise removal, video sharing, remote grading, etc, are not offered. However, it is still an excellent program for the newbies who want to get an idea of how to color correct.
  • Easy to be handled for the beginners
  • Combine video editing, color correction, and visual effects together
  • Auto color balance and matching
If you are a video lover and dreaming to make the videos seem professional-looking so that you can post them online, then video color correction is an essential part of video work. Therefore, whether you are a trained colorist or not, learning how to color correct is important. Luckily, this can be done with some tools or some video color correction software. And a good one will save your time for workflow. Hoping you can pick up the one that you feel the most comfortable with. Transform your videos by mastering how to sharpen video quality.
