AVI and MP4 formats represent the very popular and well-known file formats to most of the people prefer around the world. However, there are times when you want to convert few MP4 files to AVI format. So today, we will discuss some of the best MP4 to AVI converters.
1.     DVDFab Video Converter
DVDFab Video Converter is one of the simplest and the most easiest tools to convert any video to whichever trendy format or device you want. Moreover, you also get a free 30-day trial, wherein you can convert as many videos you want to convert without losing a single penny of yours. It is video converter tool that will convert your any-format video to the format you want in no time and with ease. It is one of the best tools to convert MP4 files to AVI files.
Apart from above astonishing features, DVDFab Video Converter gives very high quality output video that too in super fast speed. You just don’t need to waste your time anymore to convert any MP4 file to AVI with DVDFab Video Converter. Not only this, but one can also edit the videos, customize the settings, enjoy batch conversion and lightning fast conversion speed with this amazing tool. No doubt DVDFab Video Converter is the best option amongst all to consider while converting any MP4 file to AVI format.
2.     Any Video Converter
Any Video Converter is another best option that can convert everything to any format, from MPEG4 and DivX to VOB. Not only this, but you can enjoy converting over 60 other formats that includes 4K too. In addition, the interface of the software is user-friendly too. The tool has features such as customized video outputs, batch processing that can help convert various files at a time, and saving of output file which allows fast access, and so on.
3.     Zamzar
Zamzar is a prominent MP4 to AVI online converter that aids you to convert any MP4 file to AVI format in no time and with superior quality. It has a user-friendly interface that lets the users enjoy their converting of files without any issues and difficulties. It is a free-to-use tool to convert any MP4 file to AVI format.
4.     Freemake
Freemake is among the free best video converters that are available in market. It supports over 500 various video formats, and also helps you download videos straight from the famous social media platforms and other different video-sharing sites. Also, it further provides support to various devices that allows fast and spontaneous transfer including other amazing 4K resolution options. Other features that make this tool stand in the crowd are rotating and cutting videos, converting and embedding them along with subtitles, along with other useful options.
5.     Handbrake
Handbrake is an open-source video converter tool and is among one of the well-known tools used for converting and ripping video files. In addition, the tool also has playback support for various devices such as iPhones, Android tablets, AppleTV, and so on. T has a well-designed and sleek interface along with various menu tabs specifically designed for advanced features. And all this is just under one traditional interface that is simple to understand.
6.     MediaCoder
MediaCoder is a tool bundled with various conversion features. If you wish to convert an MP4 file to AVI format, or batch process various AVI files to MPEG, or simply compress several files so as to reduce memory footprint, MediaCoder is the best option for all these. For high-speed work, the tool supports NVENC, QuickSync, and CUDA encoding. It can also rip various video types from cameras.
7.     Cloud Convert
Being one of the best online tools, Cloud Convert is famous for its for simple conversions and downloads. It is a web-based software and presently supports 214 various formats such as images, docs, ebooks, and so on. Other features such as folder monitoring and batch converting are also provided by the tool. The tool further allows you to enjoy MP4 to AVI conversion of your files with very simple and easy-to-understand interface.
8.     Online-Convert
Online-Convert is very robust converters available in the market. The tool’s efficient homepage makes it more easy-to-understand and use the conversion options available immediately. It also provides various options for converting audio, video, documents, images, ebooks, and other such files. The video option allows conversion of files to MP4, FLV, MOV, and other such 20 well-known formats. Other features available are modifying the output screen size, bit rate, audio quality, and other several minor features.
9.     DivX Video Converter
DivX video converter has plenty of built-in and useful options particularly for outputs and inputs, as well as editing tools for modifying videos to any format you wish to convert. Though, the tool is behind you to upgrade your present version to the premium version, the free is better than the premium. The interface is simple, clean, and provides deep understanding of options particularly for outputs.
10.    Free HD Video Converter Factory
Free HD Video Converter Factory is very easy to use as it just has a ten-second guide. It also has simple options such as drag and drop any video in the program, making the tool very simple to use. Though the starting takes only seconds, the conversion may take a bit more. Features are good and have various options for conversion and other stud. You can also customize the output as per your requirement.
11.    Aiseesoft Free Video Converter
Aiseesoft Free Video Converter is the perfect converter you wish to have so as to convert any video format with no spyware and ads. You can simply convert MP4 files to AVI format freely and at ease. Also, you can edit the video with opening as well as the ending title. It is actually convenient that the assistant of this free MP4 to AVI converter is very useful.
Summary:
In the above article, we have discussed the various best top 11 MP4 to AVI converters, and the necessary information about each and every tool so as to get to know each tool in a better way. We have also seen how each of the tools is unique in its own way and is different from other tools. We hope that the above mentioned all the converters and their information is helpful to you in some or the other way and you have converted the MP4 file to AVI format using one of the above tools with no issues. We highly recommend DVDFab Video Converter to convertMP4 files to AVI format with ease and efficiency.
