[Update Gude] Top 5 MKV to AVI Converters Online and Offline
Summary: Are you looking for a tool to convert MKV to AVI? Here are top 5 best MKV to AVI converters that contain many useful and advanced features. Now go to check and find the one you want to convert MKV to AVI online offline.
Covert MKV to AVI with the best MKV to AVI converter. Often you might get ready for a movie night but discover that the software you have is unable to read an MKV file. Then there are 5 MKV to AVI converters, may be free, online, or paid, that can help solve such this dilemma. Now let's learn about how to such program to convert MKV to AVI.
1. UniFab Video Converter
How to use UniFab to convert MKV to AVI
Install and launch the UniFab Video Converter on your device first.
Select the video/file you want to Covert MKV to AVI, add it into UniFab Video Converter.
Customize the format and video resolution you want, then, click the Start button to convert your Covert MKV video to AVI format.
2. Movavi video converter
This is a good converter to change MKV file to AVI. Following are a brief introduction to this MKV to AVI converter.
• Convert MKV to AVI at lightning speed on Windows or Mac
• Processing of batches of files can be done, any size and number.
• Quality is maintained, even of 4K videos.
• Compression and easy editing with this MKV to AVI converter
The conversion from MKV to AVI and vice versa is easy and is showed step by step on the official website of Movavi MKV to AVI converter. HD videos that comprise of subtitles, as well as several audio tracks, also work well on this MKV to AVI converter. With the batch conversion feature, it is possible to encode several files and convert them simultaneously. The output format can be chosen to suit one’s needs and SuperSpeed technology leads to faster file conversion. Would you like to change MKV file to AVI with this MKV to AVI program?
3. Convert files
This free MKV to AVI converter is also handy if you expect to convert MKV to AVI online. Such are fucntions this video converter possesses.
• It can enable 330 combinations of output and input file formats.
• Privacy and security is also maintained as a converted file is destroyed in 24 hours.
• The free MKV to AVI converter supports different kinds of file conversion such as image, audio, and video as well as archive, documents, eBook and presentation files.
4. Apowersoft Converter
This free MKV to AVI converter is another choice to change MKV file to AVI. The advantages of this MKV to AVI converter are as follows.
• MKV to AVI conversion can be done in a simple way by following the steps below which comprise of browsing source file, setting output format that is required and then clicking on conversion button.
• High speed is provided when small video files are to be converted.
• For large size videos, MKV to AVI conversion takes time.
5. BenderConverter
This is another program to convert MKV to AVI online free. It has a free version as well as a paid version with varying features.
• It can support conversion of files from your computer, especially MKV to AVI.
• Free version only supports MKV to AVI conversion up to 100 MB.
• For larger file conversions a customer needs to register for MKV to AVI video converter free download full version with a fee of $9.95 per month and maximum file size that can be converted at a go is 500 MB.
• One can do unlimited file conversions every day.
Which MKV to AVI converter do you like best? Then a program to convert MKV to AVI? UniFab Video Converter is the best MKV to AVI converter without changing the quality of videos and it works on Windows, you can choose it or others to change MKV file to AVI free.
