"Convert  MKV to AVI" has many ways. We have jumped from a market laking of video converter to one full of ptrograms able to convert MKV to AVI online or offline. Moreover, some video supports many formats, so you can do more than  converting MKV to AVI. Now the problem isn’t finding a good converter but deciding which one you should use. There are plenty of MKV to AVI converters but which is the best MKV to AVI converter without changing the quality? Today, let's analyze each MKV to AVI converter and see how to use these tools for MKV to AVI conversion.
1. How to Convert MKV to AVI Using DVDFab Video Converter
We’re starting off with the best video converter around. Despite as an expert in MKV to AVI conversion, DVDFab Video Converter is also very easy by offering an intuitive interface and turbo-speed. With this free software in hand, you can convert MKV to AVI or any other formats, including 3D/H.265/8K and AVI, WMV, MKV, etc, and keep quality of the original. In addition, there are plenty of customization options to play with should you decide to edit the videos before converting them. With this tool you can convert MKV to AVI on both Windows and Mac.
(1) Launch DVDFab 11 and click "Converter"
DVDFab Video Converter is one of the modules of DVDFab 11. So after you download and install DVDFab 11, click the module of "Converter" before MKV to AVI conversion.
convert mkv to avi
(2) Load MKV file
Click the large “+” button in the middle to add the source or simply drag and drop the video you want to convert. You can also use the Add from Mobile option from the top left corner to load a video from your smartphone. Then start to convert MKV to AVI.
convert mkv to avi
(3) Convert MKV to AVI
Go to the "profile switcher" and select "Format". Here, you’ll want to select "Video" and then "AVI". Before you convert the video from MKV to AVI you can use the "Advanced Settings" and "Video Edit" options to customize the output. There are a lot of options here, including changing the resolution, video quality, and frame rate, cropping or trimming the video, adding subtitles or watermarks, and many more.
convert mkv to avi
(4) Save AVI files converted from MKV
After setting the output format as "AVI", pick the destination folder from the lower left corner and then press the green "Start" button. Then MKV to AVI conversion will be compleeted at Turbo-Speed, 10 times faster than the normal speed.
mkv to avi
2. How to Convert MKV to AVI Using Freemake Video Converter
Freemake MKV to AVI converter is a pretty straightforward software with minimalistic interface and a few basic options. There aren’t as many formats available as our previous entry but it does allow you to convert MKV to AVI and a few other common files types like MP4 and MPEG. You also gain access to a few editing tools like cropping, trimming, and rotating the video. Overall a pretty decent choice and gets the job done pretty fast, too. The downside is that this tool adds a small watermark to your videos after MKV to AVI conversion.
(1) Load your MKV video
Open Freemake MKV to AVI Converter and click on the "Video button" found in the upper left corner. Navigate to the location of the video you want to convert and load it up.
how to convert mkv to avi
(2) Edit MKV file
When you convert MKV to AVI, the editing options are available. Make any changes you need and then click the "OK" button.
mkv to avi windows
(3) Set  the output format as "AVI"
Click the “to AVI” button found in the bottom menu. Select the preset and the location of the output.
how to convert a mkv to avi
(4) Start to convert "MKV" to AVI
With all of that taken care of, to convert the "MKV to AVI" all you need to do is click the "Convert" button and wait until the tool finishes processing the file.
mkv to avi
3. How to Convert MKV to AVI Online
Just as its name indicates, this is an online tool for you to convert MKV to AVI. That’s both a positive and a negative because tools like these have some limitations but they can still do the job pretty well regardless. Because it’s an online tool you can use it to convert MKV to AVI on Windows and Mac.
Steps on how tto convert MKV to AVI online
(1) Visit the official website and select the "Online AVI Video Converter" option found under the Video Converter menu list.
convert mkv to avi online
(2) Load the source and wait a few moments until the video gets uploaded to the website.
(3). Use the optional settings to change the resolution and video quality or to rotate and cut the video.
(4) Hit the Convert button once you’re all done and then download the file once the process is complete. Yo'u're on the way to convert MKV to AVI.
4. How to Convert MKV to AVI Using Files Conversion
This is another online tool that you can use for free to convert MKV to AVI. However, it’s a bit simpler to use and there aren’t a whole lot of settings to mess around with, which makes the whole process somewhat faster. Given that this is also an online tool, you can use it to convert MKV to AVI on Windows and Mac.
(1) Visit the official Files Conversion website and you will be immediately greeted by the tool.
convert mkv to avi
(2) Click the "Select a File" button and upload the video you want to convert from your computer.
convert mkv to avi
(3)  Use the “Convert to” menu to select the format, which in this case will be AVI. Use the Size menu to select the resolution and then finally pick the quality of the output. This step is improtant to convert MKV to AVI.
convert mkv to avi
(4) Click the Convert button after choosing your preferences and then wait until the tool finishes processing the file.
convert mkv to avi
5. Conclusion
There are many tools that allow you to convert a video from MKV to AVI, both online and offline. Each of these tools has certain advantages and disadvantages but they are all fully capable of basic video conversion. If you’re looking for a tool that offers more advanced features in addition to simple conversion consider checking out the Video Converter from DVDFab. This is the best MKV to AVI converter for the job and routinely outperforms similar tools. You can try it for free but there’s also a premium version available that lets you access all the advanced features you will ever need from a video converter.
