Download DVDFab 11, Get 30-day Full Function FREE NOW !
Free Download
Does Xbox 360 Play Blu ray?
2020-06-15 17:17:11
   Posted by WiKi
12534
Summary: Does Xbox 360 play Blu ray? NO. Xbox 360 itself cannot play Blu-rays but you can convert Blu-rays to Xbox supported format for playback. Alternatively, find a Bluray player. Read this article and find the two solutions for "X360 doesn't play Bluray".
As the world’s most complete multimedia backup solution package, DVDFab 11 offers four major modules, Copy, Ripper, Video Converter and Creator, and some other wonderful tools like the Cinavia Removal and Enlarger AI to achieve better result. And a bunch of other useful utility tools with amazing features, such as DRM Removal, are also provided.
Can Xbox 360 play Blu ray"? I'm afraid not. ”Xbox 360 was a seventh generation video game console that was released back in the 2005. It directly competed with Sony’s Playstation 3 and Nintendo’s Wii. But Xbox 360 doesn't play Blu-ray just as the PS3 does. Xbox 360 could only play DVDs, CDs, and HD DVD. At present only Xbox One can play Blu-rays. But if you can’t afford the Xbox One then read the article till the end. I will show you how to make Xbox 360 play Bluray. There are two methods provided.
Part 1: Play Blu-ray Movies on Xbox 360 by Ripping Blu-rays to Xbox 360 Supported Formats
Can the Xbox 360 play Blu ray? NO. Can Xbox one play Blu ray? YES! Facing "Xbox 360 doesn't play Blu ray", use DVDFab Blu-ray Ripper to rip your Blu-ray discs to Xbox 360 compatible video formats. DVDFab Blu-ray ripper is a Blu-ray ripping software available for both Mac and Windows. This Xbox 360 Blu ray ripper can rip your Blu-ray discs to any known video format in different resolutions and quality. It also lets you edit the videos on the disc with its built in video editor.
This Blu ray ripping software has a built-in video profile for Xbos 360, so you can select it to load the pre-configured settings for the best quality. It processes Blu-ray discs fast as the Intel Quick Sync and Nvidia CUDA hardware acceleration technologies. Follow the tutorial below to rip Blu ray to Xbox 360-supported video formats.
"Does the Xbox 360 play Blu ray"  - NO! - Find solutions below.
(1) Download and install the latest version of DVDFab 11, which help you play Blu ray on Xbox 360.
(2) Open the program and click the ‘Ripper’ tab. Now load your Blu-ray disc in the optical BD drive. You can also load a BD ISO if you don’t have discs.
(3) After loading the ISO/disc click the ‘Video Profile Selector’ button and click the ‘Device’ tab. From this list select ‘Microsoft’ from the left side and then click ‘Xbox 360’ in the right side.
(4) Now set the quality to ‘High Quality’ and then click the ‘Video Settings’ to check whether you need to modify the video settings or they are just perfect.
(5) After checking the settings you can click the ‘Video Editor’ button to launch the built-in video editor.
The DVDFab video editor provides all the basic video editing tools with several advanced video editing tools like multi trim, add subtitles, and adding background music. Ripping Blu ray to Xbox 360 with DVDFab Blu-ray Ripper is a good answer to "Does the Xbox play Blu ray".
(6) After editing your Blu-ray disc media click ‘OK’ to go back to the main ripper function. Here check whether you need to select chapters, audio stream, and subtitles. Please click the ‘Choose Other Titles’ button to select all the videos on the Blu-ray disc. Although the answer to "Does the Xbox 360 play Blu ray" is no, we can make it with wisdom.
(7) Finally click the ‘Start’ button. Then DVDFab Blu-ray Ripper will rip Blu-ray to Xbox 360 compatible format. Once the ripping process finishes you can transfer the ripped videos to your Xbox 360’s storage for watching them on the TV.
Does Xbox 360 play Blu ray? - Yes, you have found the answers to how to play Blu ray on Xbox 360.
Part 2: The Most Recommended Player to Play Blu-rays on Computer
"Does the Xbox 360 play Blu ray"? No. But we can find a Bluray player instead besides ripping Blu ray to Xbox-supported video formats. DVDFab Player 6 is highly recommended which offers PC Mode and TV Mode, as a good Xbox360 Bluray player.
DVDFab Player 6  is an all-in-one video player with a clear support for 4K Ultra HD Blu-rays, Blu-rays and 3D Blu-rays. It is the only Blu-ray player that adapts to your computer hardware configuration. This Xbox360 Bluray player can play any formats of videos and play back DVD and Bluray videos and discs. Here are some features of this free software.
Features of DVDFab Player 6
• Fully supports 4K Ultra HD Blu-ray playback.
• The only player which supports HDR10 playback for crystal clear playback.
• High-Res 7.1 channel audio output with support for Dolby Atmos, Dolby TrueHD, DTS:X etc.
• Fully supports navigation menus on 4K UHD Blu-ray/Blu-ray/DVD discs.
• Easy to use UI.
• Can be used in two modes ‘TV Mode’ and ‘PC Mode’. For TV mode you’ll need an HDMI cable.
• Supports all kinds of 3D content like 3D Blu-ray discs, ISO files and SBS (side-by-side) or top & bottom 3D videos.
• Allows creation of playlists.
• Built-in player settings. Customize the settings while the player plays a movie.
Now you just have learned how to rip Bluray discs/ISOs to Xbox 360 compatible format and go the right answer to your question “does Xbox 360 play Blu-ray”. This is the only indirect way to watch and play Blu-rays on Xbox 360 by ripping them first to a compatible format. Alternatively, DVDFab Player 6 can also solve the problem of "Does Xbox 360 play Blu ray". If you are looking for a compatible DVD/BD/3D BD/4K UHD player, DVDFab Player 6 is the best Blu-ray player.
Just as we said in the article, the successor of Xbox 360, namely Xbox One, can play Blu-rays. If you are going to replace your Xbox 360 with Xbox One, you may want to check how to play Blu-rays on Xbox One.
Backup Blu-rays at home with up to 5 different copy modes
Featuring the most advanced Blu-ray copy technologies, DVDFab Blu-ray Copy allows you to make premium backup copies to your legally purchased Blu-ray movie/TV Show discs at home, for non-commercial use. With 5 versatile backup modes catering various demands, you can copy your Blu-rays in the way that fits your situation best.
You May Need Other Tools
DVDFab DVD Ripper
DVDFab UHD Ripper
DVDFab Blu-ray Copy
