Does PS3 play Blu ray? Absolutely YES! Many people stick to PS3 to play Blu ray despite PS4 and PS4 Pro has come to the market. Maybe it is for money saving, or it's just due to personal habit. PS3 is widely used to play games and other forms of digital videos. In fact, the game console is the very first consumer-grade entertainment system with an embedded PS3 Blu ray player. Here in this article, I will provide you with three methods on how to play Blu ray on PS3.
Part 1: How to Play Blu ray on PS3 Directly
Is it easy or safe to use PS3 to pay Blu ray? YES!  PS3 is capable to play Blu ray. Make sure your PS3 is connected with the internet and keep PS3 updated if necessary. Till now, Playstation 3 Blu ray must be at least or above the version of 1.50. Subsequently, let's get down to the steps on how to play Blu ray on PS3 direclty.
(1) Insert the Blu-ray disc you want to play into your PS3’s optical drive. Instead of choosing the Game Tab from the home menu, pick the Video Tab and then highlight the disc you just inserted. Press the X button to start playing the disc. This is the first step for PS3 "play Blu ray".
(2) While PS3 is playing Blu ray, use your controller to play, pause, and stop the movie or navigate through the menu.
(3) The triangle button to access the menu that lets you choose subtitles and adjust the volume. L1 and R1 are used for skipping between chapters, while L2 and R2 allow you to fast forward or rewind the video. The right analog stick can be used to perform a similar function but gives you a lot more precision. Finally, when you want to return to the home screen simply press the circle button.
Can PS3 play Blu ray? Yes, just follow the steps above and play Blu ray movies, on Playstation 3 directly.
Part 2: Rip Blu-ray to PS3 for Indirect Playback
Let's continue to explore the answer to "Does PS3 play Blu ray". In case your PS3 Blu ray doesn't work and save your Blu ray disc from scratches, ripping Blu ray to PS3 with a Blu ray ripper is a good choice. In order to help you wit this aspect, DVDFab Blu-ray Ripper can do a good job. This PS3 Blu ray ripper rip any Blu ray files to digital formats compatible with portable devices like PS3. The great thing about DVDFab Blu-ray Ripper is that you don’t even have to know which formats your PS3 supports. This PS3 Blu ripper comes with a number of pre-made profiles featuring PS3. In collaboration with DVDFab’s Cinavia Removal Solution, this PS3 play Blu ray software can also get rid of the Cinavia watermarksin Blu ray.
Steps on how to rip Blu ray to PS3:
(1) Launch DVDFab 11 and select the "Ripper" module in the top menu. Insert the Blu-ray disc you want to rip into your optical drive and wait until this PS3 Blu ray ripper loads it up or use the “+” button to manually add the disc or a compatible folder that’s already on your computer.
(2) Click the Profile Switcher in the upper left corner to choose a PS3-compatible format. You can pick a format yourself if you know what you’re doing or you can let the tool do it for you, as previously mentioned. Alternatively, let the software pick the format for you and go to Device -> Sony and then select the Play Station 3 option. It is very easy to let PS3 play Blu ray with this software.
(3) This step is optional, you can the Video Edit and Advanced Settings button is the main interface of this PS3 Blu ray ripper to customize your video.
(4) Set an output directory using the option at the bottom. Then click the button of "Start". Ready to rip Blu ray to PS3.
Part 3: How to Transfer and Play the Ripped Blu-ray on PS3
After ripping Blu ray to PS3-supported formats with DVDFab PS3 Blu ray ripper, how to play ripped Blu ray on PS3? Find a USB flash drive or external hard drive so that you can transfer the fileto your console.
(1) Connect the drive and then copy over the contents of the disc you just ripped using DVDFab Blu-ray Ripper.
(2) Wait until the transfer is complete and then plug in the drive into your PS3.
(3) Go to the Video Tab from the home screen and select the drive. Press the triangle button to see its contents and select the movie to play it directly or copy it to the PS3’s hard drive to watch later.
Does PS3 play Blu ray? YES! We hope this article can help you learn how to play Blu ray on PS3 in the most efficient way possible. The easiest way is, of course, to play it directly but using DVDFab Blu-ray Ripper coupled with a USB/external hard drive is sometimes a better alternative. This method is particularly useful if you’re a collector and want to keep your Blu-ray discs in pristine condition at all time. With DVDFab Blu-ray Ripper you only need to rip the discs once and then you can copy and transfer the contents as many times as you want, thus ensuring that you’ll never have to take the original discs out of their box ever again in the future.
By the way, can PS3 play DVD? YES! The PS3 console can play Blu ray discs and DVDs as long as they are sold in the same region as the console. Hence, make sure your DVDs have the same region code as your PS3 console. Next, to play DVDs on PS3 will be as easy as ABC. Just follow the above-mentioned steps.
If you also have an Xbox One game console at hand, you may be also interested in how to play Blu-rays on Xbox One.
