Download DVDFab 11, Get 30-day Full Function FREE NOW !
Free Download
Best 4K Blu-ray Burner to Burn 4K UHD Blu-rays Free
2020-06-13 08:03:53
   Posted by Gabriel; Starry
18421
Summary: This article mainly introduces world’s best and most professional 4K Blu-ray Burner designed to burn 4K Ultra HD Blu-ray with fast speed and high quality, so that you can proceed with better UHD backups and achieve stunning visual experience.
The Most Complete DVD/Blu-ray/4K UHD/Video Solutions
DVDFab 11 offers the world's best services related to DVD/Blu-ray/4K UHD/Video. It can copy, convert, or create DVDs/Blu-rays/UHDs and remove their cinavia protection if they are protected. Their original qualities can be preserved or even enhanced under the help of an AI-powered enlarger tool of DVDFab 11. Additionally, DVDFab 11 allows you to change video formats and as well as remove DRM protection.
Do you know any professional 4K Blu-ray Burner? Looking around, aside from DVDFab, it’s hard to find other alternative reliable UHD Burners. In this article we are listing two best UHD burners from DVDFab which are extremely good for copying and creating 4K UHD Blu-rays. Find these tools below. Read on to take a look at these two 4K Burner.
Part 1: DVDFab UHD Copy: Best 4K Blu-ray Burner and Copy Software
DVDFab UHD Copy is a fully functional 4K UHD Blu-ray copy solution and a 4K Blu-ray Burner that is used to copy a 4K UHD Blu-ray disc as a 4K UHD Blu-ray ISO, folder, or to a blank Blu-ray disc (BD50 and BD25). Blank 4K UHD Blu-ray discs are expensive so you may not be buying them always to make a hard copy. The best option would be to save an exact copy of the 4K UHD Blu-ray disc as an ISO or a folder. You can save this ISO/folder on your computer’s hard drive. The good news is that you can always play this UHD ISO or folder from USB connected to a UHD players or with 4K media player. So, this way you can save your money on blank 4K UHD Blu-ray discs. However, DVDFab UHD Copy isn’t just limited to making ISOs and folders. You can also choose to burn blank BD50 and BD25 discs by going to ‘Advanced Settings’. DVDFab UHD Copy provides three main functions whose description is given below.
Main Functions of DVDFab UHD Copy/4K Blu-ray Burner
1. Full Disc:
The ‘Full Disc’ UHD Copy mode actually copies the entire UHD disc to an ISO, folder, or a blank BD25/50 Blu-ray discs. If you are creating an ISO or a folder then you can choose BD100 via ‘Adavnced Settings’. Selecting BD100 will make a 1:1 lossless copy of the entire 4K UHD Blu-ray disc. If you want a compressed copy then you can either select BD50 or BD25 and can save an ISO, folder or directly burn a blank BD25/50 disc. In any case, the HDR10 and Dolby Vision quality will be retained. Select the Blu-ray drive from the ‘Save to’ location if you want to burn a compressed BD25/50 blank disc.
2. Main Movie:
A 4K UHD Blu-ray contains more than one movie file. So, the ‘Main Movie’ UHD copy mode gives you the freedom of selecting the movie file of your choice instead of copying the entire 4K UHD Blu-ray disc. Copy a single movie file will be faster and save your time from getting invested in unnecessary copying process. Simply load the 4K UHD Blu-ray disc in the 4K Blu-ray drive and open the 64-bit DVDFab 11 . Head to the ‘Copy’ mode and select ‘Main Movie’. Load the disc by clicking the +Add button, to select any of the main movie click ‘Choose Other Titles’.  You can also select the audio, chapters, and subtitles.
Only one main movie can be selected at a time. You can copy the main movie ans save it as an ISO (BD100, BD66, BD50, BD25 with 2160p quality), folder, or directly burn blank BD50/25 disc. In every case, the HDR10 and Dolby Vision quality will be retained. If you are creating a BD100 ISO, then the output file will be a 1:1 lossless copy. You can’t burn a BD100 physical disc due to compatibility issues among hardware UHD players, you can save a BD100 ISO instead. If you are burning a physical BD50/25 disc, then the original 4K UHD Blu-ray data will be compressed to fit on these discs. However, 2160p quality, HDR10, and Dolby Vision will be retained.
3. Clone/Burn:
If you just simply want to clone or burn your 4K UHD Blu-ray disc in a 1:1 lossless ratio, then go with this option. The clone option can only clone a disc to an ISO file and it can’t burn a physical BD-XL disc as I told you earlier.
So, these were the three main functions provided by DVDFab UHD Copy. I hope you got the details correctly. In a sense, this 4K Blu-ray Burner is quite helpful with versatile features and customized options to make your UHD backups professional and high-quality.
Part 2: DVDFab UHD Creator: Best 4K Blu-ray Burner for Home Player
If you are looking to create your own 4K UHD Blu-ray disc, ISO, or a folder then DVDFab UHD Creator is the world’s best 4K Blu-ray creator for you. With this 4K Blu-ray burner software, you can convert almost any video to a 4K UHD Blu-ray format. And those movies or videos can be played on a 4K UHD Blu-ray player like DVDFab Player 6. Thus, with this tool you can convert and burn your videos to blank BD50 and BD25 discs with the inbuilt DVDFab burning engine. And secondly, you always have the option to save your videos as ISO (BD100, BD66, BD50, BD25). The disc and ISO output format can be selected from the ‘Advanced Settings’.
This UHD burner software is easy to use and converts any video to 4K UHD Blu-ray format. Normally, it will take much time to create a UHD Blu-ray ISO or folder. But DVDFab 4K Blu-ray Burner/Creator, supported by acceleration technologies like Intel Quick Sync, NVIDIA CUDA and AMD, will considerably shorten the burning and conversion process. These technologies have been developed by their respective developers to enhance the processing speed of your computer hardware like Intel CPUs, Nvidia GPUS, and AMD CPU and GPU. To avail these hardware acceleration features you should have at least NVIDIA GeForce GTX 1050 or above.
With the advent of 4K technology, the 4K Blu-ray Burner is slowly becoming an indispensable part of high-definition home entertainment system. From 4K TVs to 4K media players, you can find 4K UHD Blu-ray all around.
In this article we have discussed two useful UHD burner and copy tools for burning, copying and creating 4K UHD Blu-ray discs and ISOs. In a nutshell, DVDFab UHD Copy software is really a nice 4K Blu-ray burner software for all your UHD burning and backup needs with customized options to create ISO, folder, or burn compressed Blu-ray media. And DVDFab UHD Creator helps you convert any video to a 4K UHD Blu-ray format. You can always try these two useful tools on a 30-day free trial basis before making a purchase.
Copy 4K Ultra HD movies off the original disc
With the emergence of 4K UHD TVs and 4K UHD Blu-ray players, 4K UHD Blu-ray movies also come into being. DVDFab UHD Copy is dedicated to helping users copy 4K UHD movies from a disc losslessly and save them in the format of ISO files or BD 50/25 discs. You can enjoy 4K UHD movies easily with this free software on Windows or Mac..
You May Need Other Tools
DVDFab Blu-ray Copy
DVDFab Blu-ray Creator
Burn any videos to standard Blu-rays (discs/ISO/folders) playable on home player or player software
DVDFab UHD Ripper
Rip UHD Blu-rays to various video formats for better backups
