Skip to content
DVDFab DVD Copy
Lossless backup or compress any DVD
Copy DVD to blank disc directly or save as ISO/Folder on HDD
Try for Free
100% Safe & Clean
Buy Now Time-limited
50% OFF
$42.50
I Need a Mac Version
DVDFab DVD Copy
Best DVD Copy Software to Remove Any Old or New Protection
  • dvd copy
    DVDFab DVD Copy can automatically detect and remove any copy protection without any hassle before copying DVD, such as CSS (Content Scramble System), APS (Analog Protection System), RC (Region Code), DADC, etc.
    Moreover, DVDFab’s exclusive Cloud Decryption Service ensures that even newly purchased encrypted DVDs can be decrypted timely and efficiently in the cloud server. This DVD copy software has you covered to open any old or latest DVDs in 5 to 10 seconds.
Duplicate or Compress Any DVD in 1:1 Quality
  • Lossless Backup
  • Compress in High Quality
  • Output Multiple Formats
  • 1:1 Copy DVD-9 to DVD-9 and DVD-5 to DVD-5
    DVDFab DVD Copy is designed to create a lossless DVD-9 to DVD-9 or DVD-5 to DVD-5 backup. The quality of original video and audio streams can be cloned in a 1:1 ratio. Besides, you can play the backup copies seamlessly on any home media server or media player like PlayerFab.
    dvd copy software
Copy DVD with 6 Copy Modes to Meet Diverse Needs
Full Disc
Copy all the DVD content with or without compression.
Main Movie
Copy the main movie title of DVD with or without compression.
Clone/Burn
Clone DVD in a 1:1 ratio with no quality loss.
Merge
Merge multiple DVD content into one DVD.
Split
Split one DVD-9 into two DVD-5.
Customize
Copy any titles/chapters you desire from the DVD.
To suit your different DVD copying needs, DVDFab DVD Copy offers 6 different copy modes, including Full Disc, Main Movie, Clone/Burn, Merge, Split, and Customize. Each copy mode performs its own functions to facilitate perfect backups of your DVD collections.
More Features in the Smart DVD Copier
  • 50X Faster Copy Speed
  • Generate Friendly Metadata
  • Remove Cinavia Watermark
  • Copy Any DVD in Batch at Lightning-fast Speed
    DVDFab DVD Copy software allows copying multiple DVDs simultaneously, be they DVD discs or ISO files. You can add all the DVDs you want to back up to the task queue, letting DVDFab complete the task on its own.
    Meanwhile, this DVD cloner ensures 50X faster burning speed with GPU Hardware Acceleration technology. Writing speed to disc depends on your optical drive, but copying to an ISO file or folder takes only 3-5 minutes.
    burn dvd copies
Free Experience Different Modules of DVDFab 13
  • Free Experience Different Modules of DVDFab 13
    Download DVDFab DVD Copy, and you will get free access for a 30-day trial to other modules included in the DVDFab 13 package, including Blu-ray Copy, DVD Ripper, and Blu-ray Ripper.
    With DVDFab, all your multimedia needs on DVDs, Blu-rays, 4K Ultra HD Blu-rays, and recorded (4K) BDAV Blu-rays will be fulfilled. Try this comprehensive solution for managing your digital media!
Upgrade Free DVD Copy Software to Premium
Free Paid
Lossless Backup to DVD9
Compress DVD to DVD5 -
Supported Copy Modes Full Disc
Main Movie
Full Disc
Main Movie
Customize
Clone/Burn
Split
Merge
Burning Engine 3rd Party Burning Engine 3rd Party Burning Engine
Built-in Burning Engine (More Stable)
Support Adult DVDs Copy -
Support Latest DVD Protections -
Support DADC Protection -
How to Copy DVD via DVDFab DVD Copy
  • >> Follow the video instruction
    Launch DVDFab and load the DVD source.
    Open DVDFab 13 and choose the Copy option. Insert your DVD into the optical drive, or navigate to it through the Add button. If the source is an ISO or a folder, you can simply drag and drop the file onto the main page.
    Select a Copy mode and customize the output DVD.
    Click the Copy mode as needed. Then choose the output DVD size (DVD-9/5). You can also define the volume label and change other copy options. Finally, select your output directory as a blank disc, ISO file, or folder.
    Start to copy DVDs free and fast.
    Tap the Start button to copy DVDs with lightning speed and top quality. You can cancel the process at any time, set your PC to automatically shut down, hibernate, exit the program, or do nothing at the end of the process.
80+ Millions of People Like Our DVD Copy Software
System Requirements
  • ★ Windows 11/10/8.1/8/7 (32/64 bit)
  • ★ Pentinum II 500 MHz
  • ★ 2GB of RAM
  • ★ 20GB of free hard disc space
  • ★ A DVD-R (W) or DVD+R (W) Drive
  • ★ Live Internet connection required to register DVDFab (little network traffic used)
Input
DVD-Video disc, DVD folder, DVD ISO image file
Output
Frequently Asked Questions
Can't find the answers you’re looking for? If you have other problems, don't hesitate to contact us.
Our Service Team is always ready to help. Your problem will be addressed as soon as we can.
Tips & Tricks to Copy DVD Easily
