Everything Related to Decrypt DVD and Blu-ray Discs
Summary: DVD and Blu-ray discs are often protected by Cinavia, Region Restriction or others. To copy and rip DVD and Blu-ray files smoothly, you have to decrypt the protection first. Now, there is the best free DVD copy software and DVD ripper, helping you copy DVD & Blu-ray on Windows/Mac and copy them to MP4/MKV or other formats.
1. Which is better: DVD or Blu-ray?
“Which is better: DVD or Blu-ray”? This is a question frequently asked by those who want to copy and rip DVD and Blu-ray discs/movies/folders and ISO image files. Simply speaking, Blu-ray is the next generation of DVD, so Blu-ray is better than DVD is such leading aspects as capacity and resolution. For the same movie, its Blu-ray version will be clearer than its DVD version. So Blu-ray is often the pursuit of those HD movie lovers.
2. Variety of DVD and Blu-ray Copy Protection
Many files, especially those DVDs or Blu-rays in high definition are protected to avoid illegal burn. So you need to seek a DVD or a Blu-ray decrypter for help. Before finding DVD decrypter, let’s learn about the variety of DVD and Blu-ray copy protection.
2.1 DVD copy protection
First, some copy protection methods commonly used on commercial pre-recorded DVD discs includes but not limited to “Analog Protection System (APS) scrambling”, “Content Scramble System (CSS) encryption” as well as “Content Protection for Recordable Media (CPRM)”. Before exploring how to decrypt a DVD and burn it, let’s see how such DVD copy protection work.
(1)Analog Protection System
APS incorporated into about 75% of all DVD discs is the Macrovision DVD Copy Protection system, which is an enhanced version of the technology long used to protect video types. Through the method of manipulating the signal level of the composite video, video types copied from DVDs encoded with APS become garbled and unwatchable. Fortunately, Analog Protection System can be defeated by passing the composite video signal through a hardware device that restores the proper video signal levels.
(2)Content Scramble System Encryption
Content Scramble System Encryption, shorted as CSS, is the main copy protection scheme applied to pre-recorded DVD discs. CSS works as a data interference system. Its main working idea is to set the global optical disc to six areas and protect each area with different technologies. Only the optical drive with the decoder of this area can correctly process the data in the optical disc. When using this technology protection, all the information stored in the optical disc needs to be processed by the encoding program. To access the encoded data, the data must be decoded.
CSS utilizes a proprietary 40-bit cipher that is used to encrypt the data stored on the DVD disc. When the disc is inserted into a player or computer, a series of “authentication” handshake key exchanges occur between the DVD drive and the player software. At the end of the “authentication” process, the drive allows access to the encrypted DVD data and the player can use the key it has obtained to decrypt the DVD data and play the disc.
Many DVD drives have a tendency to completely lock out access to an encrypted disc until the drive has been “authenticated”. In addition, many DVD drives will refuse to complete the “authentication” process and provide a decryption key if the disc and drive are not from the same region. Both of these situations can cause strange behavior and odd error messages on computer systems.
(3)Content Protection for Recordable Media
CPRM is a copy protection scheme that is used for Secure Digital (SD) memory cards and recordable DVD discs, including DVD-R, DVD+R, etc. Special CPRM-compatible recordable media are required, with each disc including a unique Media ID inscribed as a bar code in the inner hub area.
When a CPRM-compliant recorder detects compatible media, it uses the unique Media ID on the disc to encrypt the data it records to the disc. If the disc is copied, the Media ID on the new disc will be different and the recorded data will not decrypt correctly.
2.2 Blu-ray copy protection
Second, let’s get down to some common Blu-ray copy protection. Besides AACS, BD+ and Cinavia, there are also BD-J, 99 Titles, BD-Live, UOPs, CCL, etc. They may work differently, but the final result is caused your copied file unreadable or lost.
(1)AACS Encryption
The Advanced Access Content System is the first level of copy protection applied to pre-recorded discs. AACS is a standard for content distribution and digital rights management, intended to restrict access to and copying of the post-DVD generation of optical discs.
AACS includes a system by which the keys assigned to a particular player can be “revoked” for future Blu-ray disc releases if it is determined that those keys have been compromised. When a newer Blu-ray disc is inserted into an older drive, the drive is required to check the version of the “Media Key Block” (MKB) on the disc and, if it is newer than the one the drive has internally, to copy over to permanent non-volatile memory the newer MKB. Thus playing newer discs propagates the revoked key lists out to all drives.
(2)BD+ Protection
BD+ Protection is the second level of copy protection that is optional for pre-recorded Blu-ray discs. After the stream files are encrypted using AACS encryption, they are further mangled randomly with instructions on how to repair the mangled files stored on the disc as special BD+ instructions. These instructions run in something called a “BD+ virtual machine”, special software that Blu-ray players are required to include. The virtual machine on the player runs the BD+ code on the disc and retrieves something called the “Fix-up Table” to repair all the BD+ mangled regions on the disc.
(3)Cinavia
Cinavia is an advanced anti-piracy technology that embeds this technology (i.e. audio watermarks) into sound files to generate inaudible sound information. Even after re-encoding or external recording, Cinavia-generated anti-piracy cannot be eliminated. Information can still be identified by dedicated devices. Cinavia will embed certain protecting information in the sound of the film, such as embedding specific cinema-only information in the theater, embedding information that is only available for Blu-ray discs in Blu-ray discs, thereby preventing cinema piracy and Blu-ray Disc piracy. Cinavia has been widely used in new Blu-ray movies and Blu-ray players. More and more film manufactures use this technology.
3. Which is the best DVD and Blu-ray Decrypter?
In order to copy or rip DVD and Blu-ray files smoothly, professional decrypters are badly needed. There are DVD copy software to help you decrypt any DVD protection and copy DVD to computer.
DVDFab DVD Copy
This tool can remove the latest encryption embedded in DVDs automatically. It lets you copy DVDs to an ISO file, folder, or another blank DVD disc. Moreover, DVDFab DVD Copy provides six main modules: Full Disc, Main Movie, Clone/Burn, Split, Customize and Merge.
How to decrypt DVD by DVDFab DVD Copy?
Download DVDFab DVD Copy and upload the source.
Install the software on your device and select "Copy" functions. Now upload the source file, whether a DVD, ISO, or folder.
Choose the copy mode and personalize the settings.
Visit the left pane of the software and select desired "Copy" mode. Clone or burn a DVD if the copy mode chosen is not lossless. The program also supports defining volume labels and customizing other copy functions. At last, choose the final path to place the output file.
Start the copying process
Once you have done all customizations and settings, click the "Start" button and let the program complete the copying process. You can also cancel the processing at any time.
What's more, DVDFab Blu-ray Copy is a free and the best Blu-ray decrypter software that supports you to copy your Blu-ray discs by providing you with five unique copy modules:Full Disc, Main Movie, Clone/Burn, Customize and Merge. For the steps to decrypt Blu-rays with DVDFab Blu-ray Copy, you can refer to the above operations.
DVDFab DVD Ripper
If you want to copy a DVD to MP4 or any other formats available on mobile devices directly, DVDFab DVD Ripper is of great help. This free software works on both Windows and Mac, providing lots of convenient services.
Steps on how to copy DVD to MP4 using DVDFab DVD Ripper
Download the software and load your DVD source
Tab the Ripper option when it runs. Insert the DVD disc. If the source is an ISO file or a folder, simply drag and drop it onto the workspace.
Choose one profile and customize the output DVD video
Click "Choose Other Profile" > "Format" > "Video" to convert digital formats. Options are available to select audio tracks/language, extract subtitles from DVD to SRT format, or add external subtitles. Set video and audio parameters via 'Advanced Settings and 'Video Edit'. Select "Enlarger AI" to improve video quality automatically.
Start ripping DVDs
Furthermore, DVDFab Blu-ray ripper and decrypter is a perfect tool for ripping those encrypted Blu-ray discs. As we all know, blu-ray format can not be supported by every device. Hence, you need to convert it to other video formats like MKV, AVI, or MP4. You will find almost every video format you want your Blu-ray to rip with. For the steps to decrypt Blu-rays via DVDFab Blu-ray Ripper, you can refer to the above operations.
DVDFab HD Decrypter – Free Blu-ray Decrypter
DVDFab HD decrypter is also one of the best free DVD decrypter tools. It is a cost-free and simplified version of DVD Blu-ray Copy and DVD Blu-ray Ripper combined. This version only get two options for copying Blu-ray discs: Main Movie and Full Disc. In HD Decrypter, you are not allowed to burn BD25. Apart from these limitations, you can save Blu-ray disc as a folder and ISO and burn your Blu-ray disc to BD50.
Full Disc: Decrypt and copy the entire Blu-ray disc to a folder. If you want to create ISOs and burn a blank BD50, you will need ImageBurn.
Main Movie: only copy the main movie from a Blu-ray disc. A Blu-ray disc can have multiple lengthy movies. These are referred to as main movies. If you select this copy mode, then the longest movie will be selected by default.
In short, this article is packed with almost all the information related to decrypt DVD and Blu-rays. These software we introduced are the best DVD and Blu-ray decrypters and are good at performing their job.
