5 Best Ways to Convert MP4 to ISO at High Quality [Free and Paid]
Summary: If you are searching for the most effective tool to convert MP4 to ISO, you must check out this article, in which we have poured out the best suggestions with detailed insights.
- • Burn videos into DVD discs/ISO files/folders
- • User-friendly and easy-to-use
Introduction
Often, you might think of creating a duplicate or an image (ISO) of your CD or DVD, as most of the videos available on the web are in MP4 format. Since home DVDs require ISO, you must convert MP4 to DVD or ISO for seamless playback on your device. We have brought you the best solutions if you have tried several options but failed miserably to burn your videos to DVD discs.
In this informative article, we will thoroughly discuss the five best free and paid, easy-to-use MP4 to ISO converters with a detailed step-by-step guide and other factors to help you pick the best one. So, without further delay, let’s get started.
Top 5 Best MP4 to ISO Freeware and Online Converter
Here’s a list of the best five MP4 to ISO converters to help you convert MP4 to ISO without hassle. Picking any of these free and paid options will be easy for you as we have provided the features, cons, and usage steps for each software. Let’s look.
1. DVDFab DVD Creator
- Burns any video to a blank disc and allows saving as ISO/folder
- Outputs high-quality DVD 5/9
- It helps you bulk-burn DVD discs in just one click
- Enables the creation of stylish DVD menus
- It generates friendly metadata information like title, cast, cover, etc.
- Personalize DVD movies with free menu templates
- Customize menu design, preview and save it for future use
How to Convert MP4 to ISO Using DVDFab DVD Creator?
Step 1: Start DVDFab DVD Creator on your computer, select the Creator mode in the left panel, and choose DVD Creator. Then, tap the Add button and load your source video file. Preferably, you can also drag and drop your MP4 video file.
Step 2: DVDFab will analyze your loaded file and display the main information, such as runtime, name, audio, and subtitle information. You can customize the output parameters by selecting the preferred audio tracks and subtitle language. Also, you can add external subtitles or choose None if you don’t want any.
Step 3: Customize your DVD using the Advanced Settings and Menu Settings.
- Advanced Settings option lets you set the Output, Menu Properties, and Playback Mode.
- Menu Settings enables using the built-in DVD menu creator to personalize all the elements inside it, like editing videos, adding a background image, adjusting thumbnails, and so on.
Once done, click OK.
Step 4: Choose an Output Directory at the bottom of the screen and choose the third option: ISO. Touch the Start option to initiate the burning process and convert MP4 to ISO.
2. Freemake Video Converter
Freemake Video Converter is another MP4 to ISO converter that enables you to convert videos between 500+ formats for free on any device, whether smartphone or computer. This free DVD burning software does not limit video file size or format and helps you convert several visual and altered videos from popular sites.
- MP4 to ISO freeware is simple with an intuitive interface
- Freemake has the function of modifies and edits clips
- Converts video and audio files between 5000+ output formats
- Efficiently burns videos to blank DVD discs
- It supports to save and change streaming clips
- Does not convert protected MP4 files to ISO
- Requires updating to the Gold version for premium features
- Conversion speed is relatively slow
Step by Step Guide on How to Use Freemake MP4 to ISO Converter
Step 1: Drag and drop MP4 videos and add files by clicking the +Video.
Step 2: Hit the Scissors icon and customize your MP4 files before conversion.
Step 3: Tap the to DVD in the format bar. Now, a dialog for the DVD output parameters will appear. Simply click NO MENU and proceed to select the DVD menu type.
Step 4: You must type the video title, set volumes, and add any background image. Then, tap OK.
Step 5: Finally, click Create ISO and select a destination. Then click Convert to create your ISO file from loaded MP4 files. You can also convert ISO to MKV using Freemake.
3. Wondershare UniConverter
Wondershare UniConverter is an excellent MP4 to ISO tool with an easy-to-navigate interface that lets you convert videos with massive features. This ISO maker enables you to preset your conversion options and offers basic editing features, such as trim, crop, rotate, etc. The conversion process is fast and reliable, with a wide range of supported formats.
- Converts 4K/8K/HDR videos at blazing speed
- Supports batch conversion of up to 20 media files
- Supports high-quality lossless compression for both audio and video
- Efficiently removes noise from audio recordings
- Offers video editing functions to edit the videos at your preferences
- Often results in a loss of audio sync when converting and editing
- Limited ability to perform advanced video editing tasks
- Sometimes, software crashes and freezes during use
Step by Step Guide on How to convert MP4 to ISO using Wondershare
Step 1: Launch Wondershare UniConverter and click the DVD Burner tab on the primary interface.
Step 2: Click Add Files and import the MP4 video to be converted.
Step 3: Three editing icons will appear under the video thumbnail. Click any of them to edit your video or add a watermark to it.
Step 4: Move to the Burn Settings panel once you edit your videos, located at the right section of the screen, and in the Burn Video to section, ensure to click ISO Files.
Step 5: Tap the Burn button at the bottom-right corner and begin the conversion process.
4. DVDStyler
DVDStyler is one MP4 to ISO freeware available for cross-platforms. You can create designed menus and photo slideshows effortlessly, choose your own personalized background images, add texts, and much more. You can import videos in several formats like MP4, WMV, AVI, etc., and scale any button or graphic object.
- DVDStyler is a free and open-source program
- This MP4 to ISO freeware helps copy menu object
- Cross-platform compatibility
- Multiple languages are available
- Supports several videos and image formats
- This MP4 to ISO Converter quits frequently
- Loads files slowly sometimes
- It lacks software updates, so the UI is pretty old-fashioned
Step by Step Guide on How to use DVDStyler to Convert MP4 to ISO
Step 1: Download this free ISO burner and click File Browser at the left.
Step 2: Find the MP4 video to be converted and drag it to the program.
Step 3: Tap the + button to import files, select the Backgrounds and Buttons tabs, and design your DVD menu.
Step 4: Now, tap the title thumbnail twice to change and select the desired settings in the properties window. Then tap the Burn icon and click Create ISO image.
Step 5: You can choose VLC and preview the ISO before conversion. However, ensure your computer is equipped with the VLC media player. Once done, start the conversion process from MP4 to ISO.
5. Online MP4 to ISO Convert Free
Online Convert Free is a renowned MP4 to ISO converter online that supports converting video files to other formats quickly and without hassle. This free ISO converter does not require you to install the software and handles all MP4 conversions in the cloud so that it won’t use your computer resources in the process.
- Fast and easy conversion
- It allows a maximum of 100 MB file size
- Totally free MP4 to ISO converter tool
- It does not require downloading any software
- Converts multiple types of formats, like images, videos, audios, books
- The site is not intuitive
- Allows only three items per conversion
- The conversion process is a bit slow
Step by Step Guide on How to use online MP4 to ISO converter
Step 1: Open onlineconvertfree.com on your web browser.
Step 2: Tap Choose File and upload the MP4 file you want to convert to ISO.
Step 3: Choose ISO format for conversion and click Convert.
Step 4: Wait until the conversion is complete. Then, tap the Download button to get your converted file in the ISO.
Comparison of all MP4 to ISO Converters
Our comprehensive list of free and paid MP4 to ISO converters must have given you an insight into all their features, cons, and offerings. Have a look at the comparison table below to glance at their highlights and decide the one you feel best.
Features |
DVDFab DVD Creator |
Freemake Video Converter |
Wondershare UniConverter |
DVD Styler |
Online Convert Free |
Supported OS |
Windows and macOS |
Windows |
Windows and macOS |
Windows, Linux, and macOS |
All OS and web browsers |
Input Formats |
200+ |
500+ |
200+ |
30+ |
200+ |
Customize Menu |
Yes |
No |
Yes |
No |
No |
Edit Videos |
Yes |
Yes |
Yes |
No |
No |
Add Subtitles |
Yes |
Yes |
Yes |
No |
No |
Conversion Speed |
50x faster speed |
Slow conversion speed |
30x conversion speed |
Average conversion speed |
The Bottom Line
DVD burning software is a boon to convert MP4 to ISO. Whether you are looking for free or paid programs for Windows, Mac, or other systems, we have already listed the best MP4 to ISO converters to help you create ISO file. While you can choose any listed option, we suggest you try DVDFab DVD Creator as its intuitive user interface and GPU-accelerated technology help easily convert your MP4 files and other formats into any DVD, ISO, or folder.
