Top 10 Best Blu-ray Burning Software
Blu-ray Burning Software vs DVD Burning Software
Which one do you prefer, Blu-ray or DVD burning software to back up Avatar or other famous movies? Compared with DVD burning, there are advantages to using Blu-ray burning software. Blu-ray movies are 1080p, full of sharp images and clear details, and usually presented with a wide aspect ratio, while DVD movies are only 480p, lower in resolution than most YouTube videos, and usually displayed on a stretched 4x3 fullscreen.
  • Blu-ray provides high-quality videos.
  • Blu-ray provides backward compatibility.
  • One disc is capable of holding a amount amount of data.
With the help of Blu-ray burning software, you can get a video in high definition. Anyone with a surround sound system at home will burn videos to Blu-ray instead of DVD in order to get uncompressed 4K video and audio, together with multichannel. Thus, Blu-ray burning services are still very popular. Now, follow me to pick out the best option for your use.
10 Best Blu-ray Burning Software for Windows & Mac
Though cloud storage and USB stick are prevalent these days, disc, especially Blu-ray disc, is still an excellent way for storing and sharing large data and high definition video or movie. There are so many free Blu-ray burning software programs in the market for you to back up and create Blu-rays, so you may feel dizzy if you have to pick out the best program to use.
Don't worry, we have tested and found the top 10 best Blu-ray burning software for you. Now let's take a look at them one by one.
1. DVDFab Blu-ray Creator
  • User rating: 4.7 out of 5
  • Available on: Windows 11/10/8.1/8/7 and Mac 10.10 - 13
DVDFab Blu-ray Creator, a powerful and professional Blu-ray burning software, is used for burning various videos including HD camcorder videos, iPhone MOV videos, common SD videos, etc., to blank Blu-ray disc/ folder/ ISO file.
 i  Windows     i  Mac
DVDFab Blu-ray Creator is free Blu-ray burning software that is used for burning various videos to blank Blu-ray disc/folder/ISO file, including BD 25 and BD 50. No matter your videos are downloaded from YouTube, or recorded with a camcorder, DVDFab is able to read the source.
This flexible Blu-ray burner allows you to burn and merge more than one video into one Blu-ray disc and gives you the right to rearrange the playback order and mode. Besides, you can use this program at will and customize your own Blu-ray playback menu with the built-in menu templates. For example, you are able to set background art, music, thumbnails, text font, color, and size, as well as playback buttons in the menu template.
 Pros
  • Burn 200+ video format to Blu-ray disc, ISO image file or Folder
  • Output diverse Blu-ray formats such as BD-R, BD-RE, BD-50, BD-25, BD-9, BD-5, ISO/Folders
  • Burn videos to Blu-ray in 1:1 ratio without quality loss
  • Work at 20x faster burning speed and support batch processing mode
  • Allow you to create and design Blu ray menu flexibly and offer built-in menu templates
  • Display metadata info of the source video on the Blu-ray Menu
 Cons
  • The video editing feature only available in DVDFab's DVD/Blu-ray Ripper module.
Blu-ray Burning Software: DVDFab Blu-ray Creator
By the way, if you want to burn your ISO file to Blu-ray, DVDFab Blu-ray Copy is your best choice. This burning software is powerful enough to burn any Blu-ray disc/folder/ISO file to Blu-ray disc/folder/ISO file. Moreover, it also can burn Blu-ray to DVD/AVCHD disc (BD 5 or BD 9). This tool provides 5 burning modes, namely Full Disc, Main Movie, Customize, Merge and Clone/Burn, which can fulfill your various Blu-ray burning needs.
Blu ray burning software: DVDFab Blu-ray Copy
2. Express Burn
  • User rating: 3.4 out of 5
  • Available on: Windows 11, 7, 8, 8.1 & 10 & macOS 10.5 or above
Express Burn is another quick and easy-to-use Blu-ray burning software program. It can burn AVI, MPG, VOB and all DirectShow supported video formats to Blu-ray discs. Its advanced feature lies in that it allows you to create and manage chapters on Blu-ray disc.
This program also contains the features of Audio CD recording, Video DVD authoring and Data CD/DVD/Blu-ray writing. So it's ok to choose Express Burn if you still want to burn CD and DVD. However, its free version can only be used to burn normal CDs. For advanced functions, you need to buy this best Blu-ray burner.
PROS
 Convert AVI/MPG/VOB to Blu-ray discs in high-quality
 Easy to use and support wide format
 Allow you to select menu template and create chapters
 Upgraded performance from Intel "Tiger Lake" CPU
CONS
 The premium edition is pricey
 Lack of customized options for menu creation
 Unable to re-arrange tracks.
 No preview function
 Occasionally reported errors and crashes by users
Blu ray burning software:2. Express Burn
3. ImgBurn
ImgBurn is a free and lightweight CD/DVD/HD DVD/Blu-ray burning application that allows easy burning of various files and image files to Blu-ray discs. What sets this program apart from other best free Blu-ray burners is its ability to create playable Blu-ray discs from BDAV/BDMV folder.
Additionally, ImgBurn offers advanced options for burning CDs, DVDs, and HD DVDs, as well as the ability to create image files from computer or network files and read a disc to an image file.
PROS
 Burn Blu-ray video discs from a BDAV/BDMV folder
 Burn audio CDs, video DVDs, and Blu-rays
 Free to use and user-friendly
 Support a wide range of image file formats
CONS
 Not updated since 2013
 Not compatible with MacOS
 Unable to burn digital video to Blu-ray disc
 No advanced Blu-ray burning features, such as create Blu-ray menu
Blu ray burning software:3. ImgBurn
4. Leawo Blu-ray Creator
  • User rating: 3.7 out of 5
  • Available on: Windows 7/8/8.1/10 and Mac OS X 10.6 or later
Leawo Blu-ray Creator is a relatively comprehensive Blu-ray burning software program that can burn and convert videos in various formats to playable Blu-ray and ISO image files. There are many menu templates in this blu-ray authoring software, and you can DIY your menu according to your preferences.
There is also an option for you to burn common 2D video to 3D Blu-ray. The built-in video editor in Leawo allows you to trim, crop or add watermark to your video. The best Blu-ray burner is available for both Windows and Mac systems, but it is not totally free.
PROS
 Burn 180+ videos to Blu-ray, DVD and ISO
 Offer a built-in video editing tool
 Various disc menus and templated models
 Provide six 3D movie effects.
CONS
 Perform a little bit slowly sometime
 Image and menu button misalignment.
 Cannot modify the "Play" function in the main menu.
Blu ray burning software:4. Leawo Blu-ray Creator
5. BurnAware
BurnAware is a full-fledged Blu-ray burning program with a clean and beautiful interface. It interface is straightforward and intuitive, and all its functions and features are clearly classified into four sections, namely Data, Multimedia, Disc Images, and Utilities. You can easily find the tool you want to use.
With BurnAware, you can write all types of files like digital photos, documents, music, and videos to Data and Multisession CD, DVD, Blu-ray discs, including M-Disc. Additionally it provides tools to copy discs to ISO images or directly from disc to disc. Other utilities include the ability to backup discs, erase rewritable ones and verify data integrity on discs.
PROS
 Create Blu-ray Video discs and MP3 discs, Audio CDs, and Video DVDs
 Burn data across several discs
Extract files and folders from ISO images
 Extract audio tracks and recover data
CONS
 Not compatible with Mac and Linux
 Advanced functions are limited in the free version
 Lack of advanced Blu-ray burning options, such as create and design menu
 The package includes additional software
Blu ray burning software:5. BurnAware
6. Ashampoo Burning Studio
Ashampoo is a handy Windows Blu-ray burning program. It provides robust functionality for burning data to CD, DVD, and Blu-ray discs, including rewritable media and burning existing movies to Blu-ray. It also allows easy burning ISO images from Blu-rays, DVDs and CDs and supports Ashampoo's own ASHDISC format as well as CUE/BIN.
Besides, the Blu-ray burner also enables you to burn high-quality movies and create video CDs (VCD) or super video CDs (SVCD), as well as supports various audio formats such as MP3, WMA, and WAV for creating music CDs and offers built-in normalization for consistent volume levels.
PROS
 Work fast to create a data Blu-ray disc
 Supports Blu-ray disc burning for larger data storage
 Supports a variety of disc image formats like CUE/BIN, ISO etc.
 Allows conversion of CDs and DVDs into compressed file images to save hard drive space.
CONS
 No availiable for Mac or Linux
 No support for commercial Blu-ray video playback and menu creation
 Taking up a lot of space and occasionally slowing processing
 Unable to rename files once added
 Installer may has malware
Blu ray burning software:6. Ashampoo Burning Studio
7. CDBurnerXP
Don't be fooled by the CD in its name, CDBurnerXP in fact is also a free Blu ray burning software program for disc lovers. All kinds of CDs/DVDs/Blu-rays are supported by this burning tool. With CDBurnerXP, you can burn multiple video file, such as AVI, MP4 and WMV to video Blu-ray discs and make a copy of a Data Blu-ray.
This Blu-ray burning software also allows you to burn ISO files to discs, create ISO images from discs. The major functions of this Windows tool are all presented in its main interface, so novice users can find the right tool easily, or they can go to its official website to find the detailed burning steps.
PROS
 Burn data onto various disc types, such as Blu-ray, DVD and CD
 Create DVD menu with custom backgrounds and buttons
 Create audio CDs with different file formats
 Burn ISO files directly to a CD or DVD
 Support disc spanning burning
CONS
 It contains adware and junkware
 Very slow speed on older hardware
 The launcher shuts down after choosing a task
Blu ray burning software:7. CDBurnerXP
8. Power2Go
  • User rating: 4.2 out of 5
  • Available on: Windows 10, 8.1/8, 7
Power2Go is a comprehensive Blu-ray burning software that offers a wide array of features for burning, converting, and backing up data files on Windows PCs. In addition to its simple burning capabilities, this best DVD/Blu-ray burner software enables you to perform advanced tasks like editing the DVD menu using free templates and incorporating background music.
Moreover, Power2Go simplifies the process of converting video and audio files from desktop formats to mobile-friendly media. With its Intelligent Smart Detect feature, you can effortlessly choose the best output settings for your files, guaranteeing optimal compatibility.
PROS
 Intuitive and user-centric interface
 Burn Blu-rays and author Blu-ray or AVCHD movie disc
 Create and design DVD menu with background music
 Wide-ranging compatibility with various file formats
CONS
 No support for Mac or Linux
 Relatively slow Blu-ray burning speed.
 No preview function
 Lack advanced authoring settings
Top 10 Best Blu-ray Burning Software:Power2Go
Besides internal Blu-ray burning software, there are also some external options. Here, let me introduce some of it for your reference.
9. ASUS Blu-ray Burner
If you don't install any software on your PC, there are also best external Blu-ray burners available such as ASUS. The burner typically connects to a computer via USB or internal SATA connection, providing a convenient way to create high-capacity backups, archive important files, or transfer large amounts of data.
Blu ray burning software:9. ASUS Blu-ray Burner
 Features
  • External burner
  • Support 128 GB data storage in a disc
  • 16X video to Blu-ray writing speed
  • Burn a BD-R (XL, TL, DL, QL) and M-disc
  • Provide a free UHD software register code
10. LG Blu-ray Burner
Similar to that, this is another external LG Blu-ray burner for your choice. You can pick the best hardware here. The LG Blu-ray Burner is a device designed to read and write Blu-ray discs. It allows users to burn data, movies, or media content onto Blu-ray discs for storage or playback purposes.
Blu ray burning software:10. LG Blu-ray Burner
 Features
  • External burner
  • Speed: 16X CD-RW
  • Protect and store data reliably
  • Offer BDXL ultimate capacity
How to Burn a Blu-ray with the Best Blu-ray Burning Software
To enable you to watch Blu-ray movies at home, we'll demonstrate how to burn various video files to Blu-ray in this section. Here, DVDFab Blu-ray Creator is used as an illustration.
Step 1: Download and install DVDFab Blu-ray Burning Software
Step 2: Select the module 'Creator' and set the mode as 'Blu-ray Creator'
DVDFab 13 is a comprehensive software suite that includes multiple modules, including a Blu-ray, DVD, and UHD burner. So here you need to set the mode as 'Blu-ray Creator'. Then, click the '+' icon to import your videos.
Blu ray burning software:1. DVDFab Blu-ray Creator
Step 3: Customize with 'Advanced Settings' and 'Menu Settings'
There are two important options on the main interface: Advanced Settings and Menu Settings. You can also select audio track and subtitles, or even add external subtitles. When adding an external subtitle track, a preview window will pop out for you to synchronize the subtitles with the video.
Click 'Advanced Settings' and you will be able to set the name of your file, output Blu-ray formats and quality. You can also set the playback mode of the output Blu-ray video.
Click 'Menu Settings' and you can choose a menu from stylish templates and personalize all the elements and widgets inside the template including background art, background music, thumbnails, text font, color, and size, as well as playback buttons such as Play/Pause and Previous/Next. All in all, this DVD Menu Creator is powerful.
Step 4: Set the output destination and click 'Start' to burn a Blu-ray
You can save your burned videos to a Blu-ray disc, folder, or ISO file. After that, click 'Start' to make the best Blu-ray discs like BD 25 or BD 50.
FAQs about Blu-ray Burning Software
What is the best Blu-ray burning software?
Due to its strong features and intuitive interface for users, DVDFab Blu-ray Creator stands out among these solutions. DVDFab enables you create your own Blu-ray menu with personalized options and can convert any common video file into a Blu-ray disc, ISO, or folder.
Does Windows 11 come with a Blu-ray burning software?
No. Windows 11 offers a convenient built-in burning feature known as “Windows Disc Image Burner" that allows you to burn ISO files, which are disc image files, directly to a CD or DVD. However, if you prefer alternative options with advanced video DVD or Blu-ray burning abilities, you can explore third-party software like DVDFab DVD Creator and Blu-ray Creator.
What are the Blu-ray burning tips?
Which media should you choose:
  • Always use reliable and compatible media
  • Set target size to 23000 for BD-25 and 43700 for BD-50
  • Blu-ray disc formats: BD-ROM (read-only format for distribution of HD movies, games, software), BD-R (recordable format for HD video recording and PC data storage), BD-RE (rewritable format for HD video recording and PC data storage)
  • Set the recording speed to a lower speed to ensure the maximum quality of the burned data
  • Recommended quality media: Verbatim BD-R/RE 25GB/50GB, Sony BD-R/RE 25GB/50GB
  • Sizes: 25GB/single sided single layer-135 minutes, 50GB/single sided dual layer-270 minutes
  • Please always use the latest firmware for your Blu-ray burner and player
  • Please always use the latest version of copy/burn software
Now the features and functions of top 10 best Blu-ray burners have been listed above, so do you have any idea which one you shall choose? Among the top ten options presented, DVDFab Blu-ray Creator and Blu-ray Copy software stand out due to their advanced Blu-ray burning and customization capabilities. select one that most effectively meets your Blu-ray authoring objectives.
